Re: HP-35 problems Message #13 Posted by Michael de Estrada on 20 Mar 2009, 4:05 p.m., in response to message #12 by Randy
I disagree as to the switches being identical. The ON/OFF slider switch on my red dot protrudes much less above the surface of the keyboard than my later HP 35 v3 or all my other classics with the single large slider switch. The red dot switch protrudes less than 2mm, whereas the HP 35 v3 switch protrudes 3mm. Also, the two switches have a very different and distinct feel to them. The later version switches all have a very noticeable detent at the full OFF and ON positions, whereas the red dot has none.
Nonetheless, you are correct about fakes, as there are other signs of this, which I too will not reveal here.
