HP-67: The Red Dot Low Battery LED almost always lighting Message #1 Posted by Albert Tocar Loseggs on 11 Mar 2009, 3:57 p.m.
After rebuilt the lateral PCB (totally new, between the card reader and the CPU main board), my HP-67 works fine. But a small malfunction happens. Even the battery pack (3 x Ni-Cd 1.2 V) is fully charged, after few minutes, the Red Dot Low Battery LED (RDLBL, right – bottom on the display) lighting. The only way to turn-off the RDLBL is moving the ON/OFF switch 1 mm left => normal function / right timing. I cleaned the ON / OFF switch in order to avoid undesirable electrical contacts, but no success. I don’t know if a resistor / capacitor could be sick. Suggestions? Thanks.
