Re: Mini Challenge Message #11 Posted by Egan Ford on 25 Jan 2009, 1:58 p.m., in response to message #1 by Egan Ford
The number 48 is special in that if you add one to it, or add one to half of it, the sum is a perfect square, i.e.:
48 + 1 = 49 = 7 * 7
48/2 + 1 = 25 = 5 * 5
Using your favorite calculator how many more can you find?
I found this problem in Recreations in the Theory of Numbers by Beiler. This very inexpensive Dover reprint is very well written and a lot of fun. Chapter 22 (The Pellian) is entirely devoted to Pell Equations.
NOTE: All code will be end of this post.
MC1: Brute Force
As Thomas pointed out:
n + 1 = x2
n/2 + 1 = y2
x2 - 2y2 = -1
This program takes a single argument (number of solutions to find), then sequentially tests each odd square. The output below took over an hour (I stopped watching) with an input of 7.
MC2: Algebraic
As Thomas pointed out x2 - 2y2 = -1 is a Pell Equation. Clearly x = 1 and y = 1. To find any x the following can be use:
x = [(1 + sqrt(2))r + (1 - sqrt(2))r]/2.
However, r must be odd. See Beiler for details.
This program counts odds from 1 to 13 to find the first seven solutions in seconds. NOTE: the 7th solution is a bit off (rounding error), however the following 50g version does not have this problem:
<< 1 13 FOR r 1 2 v/ + r ^ 1 2 v/ - r ^ + 2 / 2 ^ 1 - EVAL 2 STEP >>
MC3: Recurrence Relation
As Peter pointed out this can be found here: http://en.wikipedia.org/wiki/Pell%27s_equation.
However, like MC2, for this type of Pell Equation (-1) only every other recurrence will have a valid solution. Solving for xn+2 a new recurrence relation can be obtained:
xn+1 = 3xn + sqrt(8(xn2 + 1)).
This program will compute the first 7 solutions in seconds. This was my final solution.
MC4: Recurrence Relation
This identical to Pauli's 50g version (thanks for the incredible find (A078522)).
This program will find the first 7 solutions in seconds.
The On-Line Encyclopedia of Integer Sequences is treasure trove of integer sequences. You can find many interesting solutions there, e.g. when I searched for 1, 49, 1681 I found A008843 and created the following 15C version:
001 LBL A 010 x
002 SF 8 011 COSH
003 2 012 x^2
004 x 013 CHS
005 1 014 1
006 - 015 -
007 2 016 INT
008 SQRT 017 RTN
009 ATANH
Note the requirement for complex numbers and hyperbolic functions. To use, just enter the term you want (1 through 7). NOTE: the 7th solution is a bit off.
41CX Code and Results
I liked this problem because there were so many ways to write programs for it. Thanks all for participating.
Edited: 25 Jan 2009, 2:19 p.m.
