Re: N00P question - how to clear NoV64 Message #2 Posted by Diego Diaz on 23 Jan 2009, 7:41 p.m., in response to message #1 by PeterP
As some other may face the same situation and despite that I've replied your private mail on the subject...
The procedure to erase NoV-64 RAM chips is by means of CLR_RAM4.HEX file.
Burn your module with this file, make sure you have fresh batteries and plug your module in.
Your calc will turn ON automatically after 25seconds.
[CLR OK ] message will let you know that your RAM is now erased. Turn OFF and reconfigure your NoV-64 as usual.
Cheers!!
Diego.
