Re: Just for Fun...? Message #2 Posted by Walter B on 18 Oct 2008, 2:49 a.m., in response to message #1 by Mike T.
Hi Mike,
thanks for showing and sharing the fun.
1st view: looking very nice!
2nd view rises some questions:
> Why did you swap RDOWN and RUP?
> Why is "%" so prominent on a scientific calc?
> What is L.R. for, if you won't use menus? Todays computing speed allows for calculating the results after every input in milliseconds.
3rd view results in some suggestions:
- Find a place for CLSIGMA (i.e. CLE in your notation)
- Swap PI and "%"
- Add "x<>" (like on 15C)
- Instead of SST and BST, you may wish to use the more common primary UP and primary DOWN like on 42S
- How about a primary XEQ ?
- You may drop CLR PREFIX if you agree on F F = G G = NOP
More would require a 4th view ;)
