Re: Improper fractions & Programming. Message #7 Posted by Chotkeh Software Corporation on 1 Oct 2008, 1:41 p.m., in response to message #1 by George Bailey (Bedford Falls)
True there is ALG & RPN. But it depends on the level of data entry. In this case it may not apply, due to the simplicity of the expression. But in certain cases you may want to write an equation for the variables used. A LIB is first formed and then the equation in the LIB. In that case it is more work, but it simply asks for X (1) Y(3/4) = Z is the unknown. And therefore the solver may find the answer. In a more complex equation it is recommended to use the solver. We have Free PDFs which will outline to a limit some of this procedure.
