Re: library 256 and the HP 50G Message #2 Posted by hpnut on 11 Sept 2008, 1:14 a.m., in response to message #1 by Jan Kromhout
welcome to the HPM forum.
best go the the 50G wiki http://hp50g.pbwiki.com/20%20things%20to%20know%20about%20the%2050g
"17) Transferring programs
Transferring programs to the 49G can be quite annoying for some people. This is usually due to two problems.
1. They transfer something and it comes out as a string “HPHP49-C...”
This means that the program was transferred incorrectly for some reason. This can happen if transferring with binary mode, instead of ASCII, or vice versa. The way to fix this is to type in this: 256 ATTACH MEM DROP ->A 26 + A-> (-> means the arrow character, r-shift 0)
A library called OT49 has this as a command called ObFx(Object Fix). I recommend you send OT49 to the calculator first, and then execute this command if you ever have this happen."
HTH. hpnut in Malaysia
