Re: HP50g plotting question Message #5 Posted by Hal Bitton in Boise on 5 Sept 2008, 11:22 a.m., in response to message #1 by MikeO
I've gone the rounds with this a time or two myself. With rigorous de-selected, you can manually use the "ABS" function, but that's about it...ABS will not work programmatically or in an expression.
The manual says "The CAS can solve a larger variety of problems if the rigorous mode is not set.
However, the result, or the domain in which the result are applicable, might be
more limited."
Not sure why this is...perhaps one of our resident math guru's could shed some light on this.
Best regards, Hal
