Re: MCODE - XF-Module Entry Point Symbol List Message #6 Posted by PeterP on 21 Aug 2008, 1:19 p.m., in response to message #5 by Meindert Kuipers
Thanks Meindert for your kind offer, much much appreciated!!
1) It is the VASM for X-Function module, revision C (unfortunately I don't have revision D or the CX...)
2) I will provide the list in the format you suggested. Should the first hex digit be 0? Do you want the OCT address there as well? Maybe I just give you a second file which has the same thing but with Hex and Oct so that you can make easy comparison.
Again, thanks a lot for your kind offer, I'll post the files here (should be small) instead of the unwieldy XLS sheet...
Peter
PS: You mentioned a DFSYSTEM ROM in your other post, what is it?
