MCODE question - where to savely store an address Message #1 Posted by PeterP on 20 Aug 2008, 12:04 a.m.
Where to safely store a 3-digit absolute address?
I'd like to build a little constant library of physical and financial constants. One would initialize it by running CONINT which would store the constants (say 10 constants) in 10 consecutive registers, starting with a user given register. Later, I want to be able to access each constant via X: constant number, XEQ 'GETCONST' which would place the constant in X.
For this to work I need to somehow store the address of the first constant in memory so that GETCONST knows where to look for it.
One idea is to store it in the MLDL RAM via WROM. This can be done port-independently and would work for pretty much all existing devices that can function as Q-ROM. However, such a library could never be burned on an EPROM. This bugs me but the question here is -should it?
The other option I came up with is the first three digits of the pointer register in the XF/M module. They are not used (they are normally 000), so that is good. I'm happy to assume that this means the user has a CX or a X/function module, as most/all do. Only problem is, that I need to restrict the usage of the X/F memory to have less than 16 files in its memory. (the 2nd and 3rd byte carry a counter of active workfile for the XF/M module, if that is greater than 15 it needs 2 digits which then overrides the the last of my three digits with a 0, which is the default of the operating system) Which bugs me, but should it? How many files do you have on average in your X-Memory? but 15 files are not a lot for a full 600 regs of x-memory...
So the question to the community is, which solution do you think is preferable - storing it in the MLDL-RAM via WROM, which means it can not be burned to an EPROM or storing it in the XF/M pointer register, which means one can not have more than 15 files in the XF/M Or, is there a third location where one could store an absolute address.
Thanks for your kind help!
Peter
(PS: A third option, would be to create a buffer. But that involves a whole can of worms for a simple application I really was hoping to avoid. I have not read a good description on how to create a buffer and maintain it anywhere so far, but I believe that it would mean I have to write a routine which is triggered via the polling points of my module as the OS deletes all buffers when it starts. And then I have to search for my buffer etc, etc... iiieeeee, nasty...
Edited: 20 Aug 2008, 12:37 a.m.
