Re: HP42s Programming Message #4 Posted by Eric Smith on 11 Aug 2008, 10:03 p.m., in response to message #1 by Mark Harvey
Between programs, you don't use ".END.", just a normal END.
When you're editing one program and want to start entering another one, do a "GTO ..". That will move to the end of program memory, insert an END if there isn't already one present, and leave you at the right place to insert the first instruction of your new program, which should generally be a LBL.
