Re: HP-41CV zebra strips Message #5 Posted by Muhammad Ahmad on 26 July 2008, 1:03 p.m., in response to message #1 by Tim
You can try to clean them. Even rust can be removed with WD-40. Take a Q-tip and apply some WD-40 on it and then clean the metal contacts on both ends, i.e. the PCB and the Flex cable. Once the thorough cleaning shows that the golden pads are clean, you can then use alcohol to remove the oily residue of WD-40 or even Windex. But this needs to be done with Q-tips. Avoid any of the cleaning fluid seepage into other areas. Do it very gently and precisely.
Once the contacts have been cleaned, you can take an eraser and rub it on the contacts to remove any other stuff. This should remove any debris created by oxidation. Use a magnifying glass if you have to. The work needs to be done very precisely, almost as if you are working on fine pitched SMD devices.
Hope this helps, and let me know if you have success.
Good Luck!!!
As a last resort, try changing your batteries with a set of fresh new ones.
Muhammad
