Re: Producing symbolic derivative on 48G Message #5 Posted by Roger King on 2 July 2008, 6:39 p.m., in response to message #4 by BruceH
This sort of works as long as I can switch to another directory that does not have the variable in it, or above it since the calculator searches the current directory, and the directories above it for the variable.
To include a bit more of the situation, the problem arose in a program I wrote for the 50G for propagation of errors. Actually everything works great on the 50G. Since the program was in user RPL I copied it over to a 48G and it seemed to work ok until I noticed some strange results, which turned out to be the problem at hand. There are some basic ways to work around the problem, such as being really careful about what variables are stored in the various directories, but I am looking for a bit cleaner solution that does not depend on the state of the calculator.
