HP 20b - you can display your name when it turns on Message #1 Posted by Gene Wright on 25 June 2008, 10:33 p.m.
You can customize your 20b to display your name when it turns ON by doing the following:
shift mode UP UP UP (select the language) SHIFT UP.
The screen then becomes blank and you are ready to enter your name (up to 8 characters). Use the UP and down arrow to select a letter, INPUT to validate the letter and = to erase the last letter and ON to exit.
For example to enter CDB, press UP INPUT UP UP INPUT UP UP UP . Once you have entered your name, press SHIFT OFF and then ON again and your name will display.
From the July HP Solve newsletter...
July HP Solve PDF
My 20b now displays "GENE" when I turn it on.
Available characters are:
Capital A through Z and lowercase A through Z.
and many others including many Greek letters.
Space and divide symbol
Numerals 0 through 9
and then non-English letters.
I am not aware of any way to do anything else with these characters at the moment.
Edited: 25 June 2008, 10:50 p.m. after one or more responses were posted
