Re: Prime factorization in the 48GX Message #9 Posted by Joe Horn on 16 July 2008, 12:53 p.m., in response to message #8 by Gerson W. Barbosa
Mark Adler's FACNUM (on Goodies Disk #2) is twice as fast as my HP48 factorizer. Its listing follows, with Mark's comments.
%%HP: T(3)A(R)F(.);
@ by Mark Adler
@ FACNUM (BYTES = 277.5, #74FFh)
@ Given an integer, return its prime factorization as a list.
@ For example, 16353 FACNUM returns { 3 3 23 79 }.
@ initialize factor list
{ } SWAP
@ For this part of the program the stack is: n factorlist, where the two are
@ kept so that the product of the list times n is the original integer.
@ factor out 2's
WHILE DUP 2 MOD NOT REPEAT
2 / SWAP 2 + SWAP END
@ factor out 3's
WHILE DUP 3 MOD NOT REPEAT
3 / SWAP 3 + SWAP END
@ start factor search at 5
5
@ The stack is now: k n factorlist, where the second two are maintained as
@ before, and k is the largest 5 mod 6 integer less than or equal to the
@ last factor found (execpt initially when it is set to 5).
@ search from k to sqrt(n) for factors---k must be 5 mod 6
WHILE OVER 1 \=/ REPEAT @ do while n is not one
OVER \v/ FLOOR @ go up to the floor of the square root
IFERR @ (divide by zero used as a loop breaker)
FOR i @ look at factors that are 1 and 5 mod 6
IF DUP i MOD NOT THEN
i 0 / END @ if 5 mod 6 divides n, then cause error
IF DUP i 2 + MOD NOT THEN
i 2 + 0 / END @ if 1 mod 6 divides n, then cause error
6 STEP
THEN DROP @ got an error---trash the zero
ELSE DUP @ end of loop---n divides n
END @ after this, stack is: factor n factorlist
ROT OVER + ROT ROT @ add factor to list (factor n factorlist')
SWAP OVER / SWAP @ divide out divisor (factor n' factorlist')
DUP 6 MOD 5 - 2 / + @ set k' to largest 5 mod 6 <= divisor
END @ find next factor (k' n' factorlist')
@ return list, dropping n and k
DROP2
If you want REALLY fast factorizing on the HP48, you'll have to go beyond User RPL. The best one ever written (I think) is Klaus Kalb's "FCTR" on Goodies Disk #8, in the MATH directory. It is very fast, though not as fast as FACTOR in the HP 50g, of course.
-Joe-
