Re: HP 71B With HPIB Disk Drive ? Message #2 Posted by J-F Garnier on 24 Apr 2008, 6:40 a.m., in response to message #1 by Sean Connor
The standard HP-71B commands like CAT, COPY, PURGE,... will not work due to the different protocol used by the HP-71B (simple 'Filbert' protocol vs Amigo or CS/80 used by HP-IB drives).
However, in theory you can access the drives with low levels commands (SEND, OUTPUT, ENTER) and it could a nice hobby project...
There should be no problem to use HP-IB printers with the HP-71B.
J-F
