Re: 50G involves too much learning,selling Message #2 Posted by Eric Smith on 1 Apr 2008, 9:42 p.m., in response to message #1 by designnut
The 50G is a far more powerful tool than most other calculators, so there is a lot to be learned about it. However, you don't need to know everything about it to put it to good use. A little time spent with the manual will get you going. If you're not willing to spend that time, then you are correct that the 50G probably isn't the right calculator for you.
