Re: How to capture HP-50g Display-contents Message #2 Posted by Tim Wessman on 23 Mar 2008, 1:14 p.m., in response to message #1 by Karl-Ludwig Butte
It does work. Sometimes it doesn't work for some reason anywhere in the calculator and you'll need to reconnect a few times. Basically, make sure that when you HOLD down the ON key and press the UP silver key from the stack it sends. Once that is working, you can take a screenshot at any time (with the exception of while a C program is running).
TW
