Re: HP-10 Dis-assembly Message #3 Posted by Jeff Davis on 24 Mar 2008, 9:20 a.m., in response to message #2 by Walter B
Thanks for the response. I did get the unit to open without mishap. I do have some Corrosion on the circuit board. I need to soak the board in Vinegar then clean with Alcohol. The only problem is the "zebra" Cable coming fronm the printer. Can this successfully be pulled from the board and then reinstalled? Is it ok to soak this "zebra" cable in Vinegar also? The next question is regarding the keyboard. The circuit board for the keyboard seems to be locked tight to the top case. Is this something that should come off easily? I was wanting to clean the keyboard. Thanks,
Jeff
