How to write HP-9121 floppies from a PC ? Message #1 Posted by Pascal on 15 Mar 2008, 9:45 a.m.
I have a set of floppies of windows 1.03 for the HP-150. They are single sided, double density disks with a capacity of 270KB. This format is compatible with the HP-9121 disk drive and is unfortunately not compatible with standard DOS or Windows. Some of the floppies have bad sectors and 2-3 files are not readable. For example the Windows Write disk that contains the write.exe file has a bad sector. I think I have found a way to work this out by taking the write.exe from another set of windows 1.03 disks that I have that is for the HP Vectra (5.25", 360KB). The file size and date is exactly the same so I assume it will also work on the HP-150.
In order to transfer the write.exe to the HP-9121 floppy, I would need a software that can read & write to this special format from within DOS or Windows. So far I found a software that can format and copy such disks from Windows, it's called Omniflop. It can create image files of hp-9121 floppies but it's not possible to edit those file in order to inject files.
So I'm stuck here and I wonder if anyone would have a good idea to help me continue this project. Any suggestion ?
