Using Custom (vectored) ENTER Message #1 Posted by Gerry Schultz on 15 Feb 2008, 4:49 p.m.
Hello Everyone:
I'm using vectored ENTERing to trace some programs listed in Wickes' HP 48 Insights Part 1, the GX version. In section 12.11.2 (pg 397) and 12.11.3, Prime Numbers and Prime Factors respectively, Mr. Wickes has three programs I would like to trace using my 82240B and my HP49g+.
I've typed in PRIMES1, PRIMES2 and FACTOR and they all work as described in the book. I also closely read and studied section 7.4, Vectored ENTER (pg 206) and reviewed James M. Prange excellent "48/49 series print trace / vectored ENTER" posting back at the beginning of 2007. I've typed in and confirmed that the TRON and TROFF programs correctly generate alphaENTER and betaENTER global variables. I went as far as to verify that /Ga in the program is the right alpha character, character number 140 and /Gb is the correct beta character, character number 223 in the 49g+. The alphaENTER and betaENTER global variables are in the same subdirectory as the three programs, PRIME1,PRIME2 and FACTOR. Finally, I've confirmed that both flags -62 and -63 are set.
When I run any of the three programs with the above setup, none of then generate a trace print. My input prints on my printer and the program output prints, but no trace printings in between. None of this Custom ENTER stuff is difficult to figure out so I think the problem must relate to Wickes' programs using stack manipulation and not explict ENTERs to move his data around.
With no ENTERs in the program, will vectored ENTERing allow you to trace a program with a printer? Will implicit ENTERs allow tracing in a program?
Sorry for the long nature of this post. I just wanted to make sure I had covered all the pieces that are required to make vectored ENTERing work.
If you have any insights, thank you. I'm curious to see what I'm missing or doing wrong. I also checked the comp.sys.48 group to see if they had any insight but without success.
Thanks,
Gerry
