"Machine Reset" and coma mode on the HP-27S Message #5 Posted by Karl Schneider on 3 Jan 2008, 11:51 p.m., in response to message #4 by MitchT
Martin and Mitch --
I'm not sure why Martin's HP-27S reset itself (low batt, perhaps?); the reset will retain memory contents, and change settings (including display contrast) to default values.
The only advantage to "coma" mode is battery conservation. The clock cannot be turned off otherwise, and its constant running will discharge the expensive cells significantly faster (at $10 for a set of three quality Silver Oxide cells). Of course, if you use the time-based functions, then it's best to turn it off normally.
Simply turning the calc back on will awaken it from "coma" mode, with a Machine Reset.
All of the above also applies to the HP-17B, HP-17BII, and HP-42S, except that the latter has no time clock.
-- KS
Edited: 3 Jan 2008, 11:55 p.m.
