Adv+CCD+Games in 41CY or Rambox Message #1 Posted by PeterP on 30 Nov 2007, 5:18 p.m.
I was wondering if someone could maybe help me out. I'd like to copy the Advantage Module, the CCD Module and the Games module into my CY at work (64k Rambox).
I think from the XROM numbers we are fine, AFAIK:
CCD - 9,11
Adv - 22,24
Games - 10
From a space perspective, we should be fine as well. With the modules plugged in as follows, all seems to be fine:
page 8 - Rambox OS
page 9 - empty
page 10&11 - CCD
page 12 - Games
page 14&15 - Advantage.
However, when using just the Rambox/CY, I do not seem to be able to
1) copy the CCD (no access. copy protection)
2) copy the advantage (crash)
The first problem I understand (copy protection on CCD) but don't know how to circumvent, other than going via IL+ISA-IL to PC card or maybe (I think I found a way once) via the MLDL + USB to download onto the HP41 the rom-files. If someone knows a better way, I'd love to hear about it
The second problem I don't even understand. This is what I tried:I plug in the advantage into say page 10+11 and then use the Rambox-OS to do a pagecopy to 14&15 and then turn off the HP41, unplug the physical advantage module, turn the HP41 back on. It is then in a somewhat crashed state. It either does not turn on (unless I use the enter+on trick) or freezes. Only a memory lost with clear rambox yes restores it to working condition. Could my Advantage Module be faulty?
Anyway, would love hear your thoughts as, if possible, I'd prefer not to have those modules plugged in but stored in the Cy directly.
Thanks so much for your kind time!
peter
