Re: HP-48sx repair Message #2 Posted by Allen on 23 Nov 2007, 2:00 p.m., in response to message #1 by Carl Mannheim
with your right-thumb, press on the bezel just above the [D] Key while pressing the on button. If that solves it, you can fix it temporarily by placing a rubber band on the bezel.. not worth fixing if you can pick up a used one fairly cheaply.
Edited: 23 Nov 2007, 2:00 p.m.
