Re: VIEW on HP 41CV Message #8 Posted by Karl Schneider on 22 Nov 2007, 4:37 p.m., in response to message #1 by Alfredo (Italy)
Hello, I recently bought a 41 CV on Ebay. Today I noticed a behavior which I found somewhat strange. When I use the VIEW function, it just recalls the contents of a register in the same way as RCL. The recalled value then remains in the stack! The manual says that it should show the contents without disturbing the stack, so I was expecting something like VIEW on the 35S.
This does seem abnormal, but are you absolutely sure that the VIEW'ed value is being placed on the stack? As Eric Smith suggested, try loading each location of the stack with a known value, then VIEW a different value. The VIEW'ed value is displayed, but should not be placed on the stack. CLx will then revert the display to the x-register value.
BTW, VIEW doesn't work exactly the same on the HP-41 versus on the HP-35s/33s/32SII/32S. On the latter set of models, ENTER will place the VIEW'ed value into the x-register. On the HP-41, ENTER works in conventional fashion, copying the x-register to the y-register.
-- KS
Edited: 22 Nov 2007, 4:39 p.m.
