Re: Another question on HP-41 memory modules Message #7 Posted by Karl Schneider on 18 Nov 2007, 5:35 p.m., in response to message #6 by Eric Smith
Hi, Eric --
If the calc you were transferring the XMEM into didn't also have an XMEM installed (to be replaced)
It did not, unfortunately, although I do have two X-Mem modules.
and the base XFN module full,
That's what I tried to ensure: exactly 124 registers used on both the HP-41CX built-in X-mem and the X-Functions memory.
it won't think the file chain continues into the XMEM.
And the XMEM needs to be transferred into the same kind of port (left vs. right).
I'm not sure if I did that.
With your helpful tips, I might try it again sometime. Thank you. It's certainly easier, however, to use the card reader for that purpose; I have a working, refurbished one.
-- KS
