Re: Constants in the HP35S Message #2 Posted by James M. Prange (Michigan) on 11 Nov 2007, 2:16 p.m., in response to message #1 by J-F Garnier
I don't know for the HP50. Was it updated with new constant values too?
No, it uses the same ROM, equation libraries, and periodic table library as the
49g+. For that matter, with a few simple tricks, this ROM (although without
the Saturn+ speed-up tweaks) can be used on the 49G as well.
The equation and periodic table libraries are ports of the libraries on the
Solve Eq Lib card for the 48SX, and as far as I know, no constants were
changed. In particular:
G: 6.67259E-11_m^3/(s^2*kg) G: 3.32208E-11_lbf*ft^2/lb^2
k: 1.380658E-23_J/K k: 7.270063E-27_Btu/°R
R: 8.31451_J/(gmol*K) R: 10.73164_psi*ft^3/(lbmol*°R
Does anyone know whether any "constants" have been "officially" revised from
what they were when the 48SX was current?
By the way, if you're using ROM revision 2.01-2, then I recommend upgrading to
either the latest "official" ROM,
Version C Revision #2.09
(build 92) (but use the
newer libraries), or
maybe the newer "unofficial"
Version G
Revision #2.10-7 (Build 93).
Regards, James
