Printing from HP48/49 to HP laser printer Message #1 Posted by Patrick Rendulic on 8 Nov 2007, 1:29 p.m.
Hello.
Recently I have been playing around with my HP48GX, HP49 the HP infrared printer (type A) and a serial OKI printer.
Printing to the infrared printer is no problem. Unfortunately this only works with the HP48 as the 49 has no infrared. I also managed to print from both calculators to the OKI via a serial connection (but only in text mode). Unfortunately the OKI is not Epson compatible so I cannot use the HP48-Epson driver for graphics.
As there is a HP-PCL driver available for the 48, I am interested in printing to a HP Laser Printer (I have an old Laserjet 5 and a Laserjet 1200). Before buying a serial to parallel converter, I would like to ask 2 questions:
- Does any serial to parallel converter work?
- Will the HP49 print to the Laserprinter, at least in text mode (as far as I know there is no dedicated driver available)?
- Can someone report his experiences?
Many thanks for every answer.
