Re: Application to convert Hp 41C programs into Hp 50g pgs.? Message #3 Posted by James M. Prange (Michigan) on 25 Sept 2007, 11:55 p.m., in response to message #1 by Miguel Reznicek
Has anyone out there written an application that converts Hp 41C programs into Hp 50g programs?
I rather doubt it; programming these different models is just so,
well, different.
Other than Thomas's suggestion of using a 41 emulator on the 50g,
I'd think that the best thing would be to study the programs
enough so that you really understand how they work, and then,
otherwise pretty much "from scratch", write programs to accomplish
the same things on the 50g.
If RPL models are new to you, then you might start by reading Bill
Wickes's HP 41/HP 48 Transitions, available on
the Museum CD/DVD set. See
http://www.hpmuseum.org/cd/cddesc.htm.
Regards, James
