Re: Program "Ephemeris" for HP CV 41 Message #2 Posted by Karl-Ludwig Butte on 18 Sept 2007, 4:50 a.m., in response to message #1 by Catello
Hello Catello,
to enter X<>Z do the following:
press:
XEQ
Alpha
X
shift I
shift J
Alpha
Z
shift is the yellow key. After the second press on "Alpha" the display should read: X<>_ _. After pressing the dot the display should read X<> ST_. Now only "Z" needs to be pressed.
Hope this helps.
Karl
