Re: HP 94 Battery Pack Message #2 Posted by Katie Wasserman on 25 Aug 2007, 9:52 p.m., in response to message #1 by Donald Williams
I've rebuilt a couple of 94 battery packs, they take some time.
The way I did it was to peal off the rubber grip, cut out a large section of the housing where the grip was using a tiny Dremel circular saw. Then I replaced the cells with 4 AA ni-cads because it was too hard to fit the original 2/3 C cells into place within the opening that I cut. Finished by gluing the removed section back into place and put the rubber grip back on. I used carpet tape to put the grip on with, it's a really sticky double-sided tape and exactly the right thickness.
The packs look untouched when completed because the rubber grip hides all the ugliness.
