Re: should I return the HP35S from Walmart and wait for one from Samson Cables? Message #5 Posted by Ed Look on 8 Aug 2007, 11:50 a.m., in response to message #1 by andrewj
Unless it's really a huge slant up to the right (or left, though I haven't heard of any of those) and bothers you no end, I'd keep it. I got mine via Buy.com and there is an ever so slight misalignment up toward the upper right corner, but as many say, it's really only noticeable if you run the self-test and all the annunciators show up on the screen. In fact, I didn't even notice it until I read the posts in this forum!
I have a slightly different problem, though, my case is slightly defective: the upper strap inside when the case is right side up came incompletely sewn onto the case on the left.
