Re: W&W Rambox battery change? Message #2 Posted by Tony Duell on 1 Aug 2007, 4:19 a.m., in response to message #1 by Dave Colver
Is this the one in the card reader case?
If so, you can unclip the top part of the HP41 connector section (after separating the case and removing the upper PCBs). Then the bottom board just lifts out.
It's the same as removing the main PCB from an HP41 card reader if you've ever done that.
Alternatively, if you can wait just over a week, bring it to the next HPCC meeting and I'll show you.
