35S Benchmark test Message #3 Posted by Ralph on 27 July 2007, 9:12 a.m., in response to message #2 by Xerxes
Thanks. I didn't find the conversion but it was getting late last night. You are correct on the time for the 42S. I didn't search the page, just eyeballed it. And misread or typed, common for me. I know it's blazing fast on my HP4705 Pocket PC.
I think the use of the two indirect register variables, I&J plus using the ISG & DSE commands over the math make the 42 version run faster on the 35S. Given the calculator is said to check whether the math is conventional or vector.
The 42 code went in almost as written. I put a little bit in the front to set the index range so to not have to do it manually. Probably added a second or two.
I find these tests fascinating. For my use, my program runs at the same speed on the 33 or 35 as far as I can tell.
