Re: Dual HP-IL adapter for HP-71B Message #2 Posted by Rodger Rosenbaum on 25 July 2007, 5:18 p.m., in response to message #1 by Olivier (Wa)
It allows two HPIL modules to be controlled by a single HP71.
As an example of its use, one could connect an RS-232 adapter to one of the HPIL modules, and some other device to the other. Then the output of a debugger (say) could be sent to a monitor connected to the RS-232, while the other device performance could be tested with the debugger, completely independent of the IL loop sending debugger output to the monitor.
