Re: comparing early flex circuit vs late rigid circuit series30 calculators Message #2 Posted by Hal Bitton in Boise on 8 July 2007, 9:56 a.m., in response to message #1 by Which Dr.
The earlier flex PCB 30 series machines had 2 distinct caracteristics:
1. They were rather heavy, as they had a steel plate inside to back up the flexible circuit boards.
2. The key detents were VERY firm with long travel (they used plastic snap domes).
One more thing
Because the flex circuit board machines were solderless, they were prone to having display segments blank out occasionally (a little twist on the housing usually brings them back).
Hope this helps.
Best regards, Hal
