Re: EMU71 text file via DOSLINK Message #2 Posted by J-F Garnier on 4 July 2007, 6:43 a.m., in response to message #1 by Egan Ford
You should use RESTORE IO, not CONTROL ON. Possibly RESET HPIL, then RESTORE IO.
When I'm importing large files (for instance large programs or large assembly source files I'm editing on PC), I add a final line like "*EOF", and check for A$="*EOF" to properly exit the loop and close the file.
J-F
