Fix HP15C, was re: New HP42S Message #6 Posted by Mike Ingle on 5 July 2007, 5:54 a.m., in response to message #5 by Alexander Wassermann
Check the archives for fixthatcalc's response to my question.
I got some Loctite super glue with an activator pen. Put the machine face down on a washcloth or other padded surface. Remove the back, and remove all the broken mushroom heads. For each broken one, press the circuit board down so the keys are firm. Treat the stake and board with the activator pen, and put a very small amount of super glue (I used a toothpick) on the stake and board where they meet. Keep it pressed down for a couple of minutes. A few seconds is not long enough. After reassembling, use rubber cement to attach the feet.
The 15C and 41C series have a basic flaw in that they rely on constant tension, in an organic material, to keep them working. HP did not know they would be collectors' items in 20+ years when they made them.
Mike
