Brightness display HP65 Message #1 Posted by Ronald P on 18 June 2007, 3:33 p.m.
I have a HP65 in repair this moment. There was one element in the Led burned out so I had to replace that led unit. It works 100% now for all digits. But now the brightness is different between the units.
I know HP did match the brightness at production for the 3 units, but unfortunately I had only on spare unit, so no option to match brightness.
Is there a way to make a unit less bright, can I put a (small) resister somewhere, or lower the value of the inductors affecting only one unit ?
Thanks
Ronald
Edited: 18 June 2007, 3:34 p.m.
