Re: Resetting when changing batteries? Message #2 Posted by Tim Wessman on 7 May 2007, 12:50 a.m., in response to message #1 by PhysicsNerd
Just so you know, this forum is mainly dedicated to older "collector" models. Sure, most people on here have some newer calcs, but the best place for 50G discussion is probably the newsgroup: comp.sys.hp48 (which can be conveniently accessed here - http://groups.google.com/group/comp.sys.hp48/topics ) You will generally receive many more answers there, and can conveniently search thousands of messages.
As to losing your settings, the only way that should happen if you changed the 4AA batts is if you don't have the backup memory battery (the "watch" battery) installed or if it were dead.
TW
