HP-49g+ "Insufficient memory" message Message #1 Posted by Antonio Maschio (Italy) on 23 Mar 2007, 5:04 a.m.
I happened to load HP-Lua into my calculator, copying the HP-lua file into Port 0, which had 224 KB free. When I tried to move the HP-Lua file from port 0 to port 2, I probably messed up things, since the calculator refused to do it, and after ON+F3 I found -port 0 void, -port 2 with no such HP-Lua file -and (worse) port 0 reporting 102 KB free.
I know I should defrag port 0 to recover lost chunks, but how can I do it?
Thanks in advance.
-- Antonio
