Re: dv6258SE base hot when using Message #2 Posted by Eric Smith on 1 Mar 2007, 8:01 p.m., in response to message #1 by Scooby Doo
This isn't really the right forum, and I don't have that model (I've got a dv5210us), but basically all laptops/notebooks do that. A laptop typically uses 30-40W, and converts more than 95% of it to heat. By comparison, a heating pad uses about 8W and reaches 170-180 degress Farenheit. So naturally the laptop will get very hot, and won't be too comfortable on one's lap.
If the laptop has a fan, make sure the vents are not obstructed, as the forced air cooling will exhaust some of that heat into the room rather than your lap.
