Re: hp 50g rom? Message #5 Posted by James M. Prange (Michigan) on 13 Aug 2006, 10:00 p.m., in response to message #4 by LUIS
See this comp.sys.hp48 thread.
What it boils down to is that previous equation libraries for the 49 series used unsupported entry points, and thus were ROM revision dependent. The equation libraries included with the 50g use only supported entry points, and thus work with any 49G, 49g+, or 50g (at least back to the 49G ROM revision 1.18). Unfortunately, HP forgot to include the current equation libraries with the revision 2.09 (build 92) ROM, so it works well with the 50g, but the equation libraries from the 49g+ don't work with it.
So, to use ROM revision 2.09 with a 49g+, you can export libraries 226 and 227 from an emulated 50g in EMU48 (incuded with Debug4x, see: http://www.debug4x.com/), or download the libraries from http://www.hydrix.com/Download/Hp/4950Libraries/, or wait a few days for HP's webmasters to get around to posting a ZIP file that includes them with the latest ROM. Purge the old libraries 226 and 227 from port 2, and copy the new libraries to there.
Regards, James
