Re: HP-41 IR module as remote control? Message #3 Posted by Vieira, Luiz C. (Brazil) on 6 Aug 2006, 11:27 p.m., in response to message #1 by Geir Isene
Hi, Geir;
I guess that by using specific control routines (MCODE) one could mannage to have the IR module to send a set of characters that would normally not be sent with regular printing protocol. What I believe that cannot be changed are the signal characteristics, meaning the beam modulation waveforms. These waveforms can be observed at the Hewlett-Packard Journal, October 1987 issue, p. 18. I think that there is no way to change these characteristics. Somehow off-topic: based on the HP41 behavior after having an IR module connected to it, I believe it is more related to the HPIL structuire than to the original HP82143A peripheral printer.
The main issue, for me, is the distance range. I think that much of battery power is consumming when transmitting, and that might be the main reason the transmitting maximum distance is reduced to less than 18 inches, as stated in the 82242A IR Printer Module's manual.
Hope this helps. Not so good news, though... :(
Cheers.
Luiz (Brazil)
