HP33s and HP32sII programmation difference Message #1 Posted by David Boileau on 13 July 2006, 3:41 p.m.
First, excuse me for my bad english.
I just bought a HP33s as a replacement for my HP32sII which if fallen from my desk
I use the HP33s in RPN mode and I have just written a small program that I used 20 times a day with the 32sII
The aim of the program is to compute the total area in cm² of y circles of radius x (in mm)
This is very, very useful for my job (steel reinforcement in concrete)
I enter data in this manner : number of circles ENTER diameter in mm then XEQ A
The program :
A0001 LBL A
A0002 x²
A0003 400
A0004 /
A0005 pi
A0006 x
A0007 x
And that's all.
With the HP32sII the answer was only in the x register of the stack.
With the HP33s, the answer is in both register x and y. And this is a BIG problem for me (I use the program several times in a row and I sum the answers)
I have tried the program by entering manually the instructions, and so I only get the answer in the x register ! So my program is correct !
I've tried 36 tips in the program to change this (for example, A0008 R(low)). But with every tip I get answer in both X and Y or no answer at all
Precision : I begin data introduction when all registers of the stack are at zero
Does someone has an idea ?
Does the stack behave differently between HP32 and HP33 ?
Thanks a lot
David
