The best sequence would be... Message #3 Posted by Vieira, L. C. (Brazil) on 14 July 2006, 7:57 p.m., in response to message #1 by Randy VanValkenburg
Hi;
this is just to enhance Iņigo´s answer, that is correct by itself.
The best way to change the radix mark (decimal separator) in any Voyager (HP10C, 11C, 12C´family´, 15C and 16C) is:
1) Make sure your calculator is turnned off;
2) Press and hold the [.] key;
3) while holding the [.] key, turn the calculator on;
4) release the [.] key.
This sequence toggles the decimal separator (and thousands and well) between dot and comma.
Hope this helps.
Edited: 14 July 2006, 7:57 p.m.
