HP41CX Clock Anomaly Message #1 Posted by Jason on 13 July 2006, 12:02 a.m.
My HP41CX has an unusual and baffling clock function problem - but I'm not sure if its a hardware problem or a simple setting problem - I suspect its hardware.
When I activate the clock function via "SHIFT + ON", it displays the clock every second for 3 times only and stops on the 3rd time displayed. eg
"SHIFT + ON"
displays
"3:01:25 PM"
"3:01:26 PM"
"3:01:27 PM" <------ this then remains displayed on screen - no
further increments are displayed.
The clock normally is supposed to display the time continuously every second, but each and every time it only displays time for 3 seconds and stops changing after 3 seconds. The clock itself is still incrementing correctly irrespective of the display because if you again activate the clock again it shows the correct time but only displays the changes for 3 seconds again and halts changing the dislay on the third time display eg
"SHIFT + ON" 30 seconds later displays:-
"3:01:55 PM"
"3:01:56 PM"
"3:01:57 PM" <------ this then remains displayed on screen
again - no further increments are displayed.
All other calculator functions are OK and it just seems to have this one anomaly with the clock.
A complete reset has no effect - is this just a weird hardware problem (which I suspect) or is it a setting problem with the clock.
Thanks Jason
