Re: 48gx display problem Message #2 Posted by bill platt on 11 July 2006, 3:12 p.m., in response to message #1 by Nathan Loden
push on the faceplate above the letter "F" while pressing the keys. As long as you press, it will work.
Someone suggested removing batteries, soaking in pure water, and then leting dry for a few days. The idea is that the foam pad that applies pressure to the surface connectors in that area will swell enough to remove the symtoms.
Just don't give your calculator any aspirin; you don't want to reduce the swelling ;-)
