TVM algorithm for FV with long-term high-interest Message #7 Posted by Karl Schneider on 7 June 2006, 12:20 a.m., in response to message #6 by tony(nz)
Tony --
With PF=1 and END mode, n=360,i%=10,PV=100,FV=0, solve for PMT, solve for FV, see -100, which is as you say the correct exact solution, if we interpret the other values as exact. Now try PV=144, FV=0, solve for PMT, Solve for FV and see -1000. The 12C still gives 0, which is somewhat closer to -144 than -1000 is.
I only chose 144 because it is 12*12, but all other values stimulate either zero or a power of ten in the FV, in the neighbourhood of -PV.
Interesting finding! I had not tried other values corresponding to PMT = -PV/i on any Pioneer-series financial, figuring that the code had been refined and that the answer would always be correct.
Yup that behaviour started with the 18C clamshell in 1986.
The 18C/28C were the first calculators to utilize the Saturn processor introduced with the HP-71B. HP took opportunities to improve algorithms to exploit the 64-bit, 12-digit words and faster processor. My favorite example is taking the sine of 3.14159265358 radians -- Pioneer models give the next 12 digits of pi (979323846264x10-12, the correct answer); pre-Saturn models can accept only 10 input digits (3.141592653), then give only the next two rounded digits (5.9x10-10) as the answer. But I digress...
From page 207 of the HP-12C manual, the TVM equation (with no odd period) is
(1.) 0 = PV + (1 + iS)PMT*[(1 - (1+i)-N)/i] + FV(1+i)-N (i not = 0)
With S = 0 for END mode, this simplifies to
(2.) 0 = PV + PMT*[(1 - (1+i)-N)/i] + FV(1+i)-N
Solving for FV,
(3.) FV = -PV/(1+i)-N - PMT*[1 - (1+i)-N)/(i*(1+i)-N)]
Which is what I assumed the 12C/p were using. From your example, with i = 0.1 (10% per period) and N = 360, (1+i)-N = 1.255x10-15. Therefore, 1 - (1+i)-N = 1, within the limits of the calculators (if internal extended precision is not used), and the calculated FV is simply 0 -- the difference of two identical enormous values.
However, the multiplicand to PMT can be separated into two terms and regrouped, yielding the following:
(4.) FV = (-PV - PMT/i)*(1+i)N + PMT/i
Obviously, if (-PV - PMT/i) = 0, then the term (1+i)N doesn't matter, yielding FV = PMT/i.
In your example, with PV = 100, PMT = -10, and i = 0.1, FV = PMT/i = -PV = -100 is correct.
If (1+i)N = 1 (as for extremely small i, due to roundoff error), then we get the erroneous result FV = -PV, and no value of payment can be applied.
I suppose that very large values of PMT/i could cause roundoff error in certain situations...
Quote: I prefer consistency of the 12C.
I would prefer "consistent correctness" wherever possible, and thought that the Pioneers were indeed using Equation (4.). Apparently, I was mistaken. Only for PV = 100 and PMT = -10 is the correct answer of FV = -100 produced, seemingly by mere coincidence.
Best regards,
-- KS
Edited: 10 June 2006, 9:06 p.m. after one or more responses were posted
