HP97 adapter Message #1 Posted by Hal on 17 May 2006, 4:18 p.m.
Hi Folks,
I just purchased and recieved an AC adapter (supposedly) for my HP97, which appears to be not quite compatable with my machine. The problem is, my 97 has a partition between the contacts where the adapter plugs in, but the adapter does not have a big enough notch to accomodate the partition (there is a notch separating the female contacts on the adapter plug, but it's too small. It appears that if I either got rid of the partition or opened up the notch on the adapter, it would work. The no-load output from the adapter is about 12VAC.
Can I just open up the adapter plug notch and use it?
Any help appreciated. Best regards, Hal PS...link to item I purchased
